Hi All
I am using Honeybee to simulate solar irradiance for a PV system. I used the “HB Annual Results to Data” component and “Flip Matrix” to obtain 8,760 hours of results for the eight sensors of the surface.
But here is a question, how can I split the whole result into individual results for each surface. I know that I can select each surface through List item in the output result.
But if there are so many surfaces, this might not be operational. Is there any easy way to automatically output the results of each independent surface? Can anyone help me?
radiation.gh (59.3 KB)
