Honeybee Severe Error Issue - 25 Invalid Number in Numeric Field#1 (Heating Sizing Factor)
I’m having issues running an energy analysis for the first time. I believe the problem is in this line: “IDF line~25 Invalid Number in Numeric Field#1 (Heating Sizing Factor), value=NONE, in SIZING:PARAMETERS”. I’m not sure of where to start in troubleshooting this. I’ve attached the file.
Thank you,
See the errors and warnings below:
{0;0;0}
  1. Current document units is in Meters
  2. Conversion to Meters will be applied = 1.000
  3. [1 of 8] Writing simulation parameters…
  4. [2 of 8] Writing context surfaces…
  5. [2 of 8] Writing context surfaces…
  6. [3 of 8] Writing geometry…
  7. [4 of 8] Writing Electric Load Center - Generator specifications …
  8. [5 of 8] Writing materials and constructions…
  9. [6 of 8] Writing schedules…
  10. [7 of 8] Writing loads and ideal air system…
  11. [8 of 8] Writing outputs…
… idf file is successfully written to : R:\Green\SuRG\Building_Performance_Analysis\2016_analysis_studies\Energy_Analysis_Comparison\Honeybee_+_Ladybug\tutorial01\EnergyPlus\tutorial01.idf
  1. Analysis is running!..
Done! Read below for errors and warnings:
  1. Program Version,EnergyPlus, Version 8.5.0-c87e61b44b, YMD=2016.10.31 11:39,IDD_Version 8.5.0
  2. ************* IDF Context for following error/warning message:
  3. ************* Note – lines truncated at 300 characters, if necessary…
  4. ************* 24 Sizing:Parameters,
  5. ************* Only last 1 lines before error line shown…
  6. ************* 25 None, !- Heating Sizing Factor
  7. ** Severe ** IP: IDF line~25 Invalid Number in Numeric Field#1 (Heating Sizing Factor), value=NONE, in SIZING:PARAMETERS
  8. ** Warning ** IP: Note – Some missing fields have been filled with defaults. See the audit output file for details.
  9. ** ~~~ ** Possible Invalid Numerics or other problems
  10. ** Fatal ** IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination.
  11. …Summary of Errors that led to program termination:
  12. … Reference severe error count=1
  13. … Last severe error=IP: IDF line~
  1. ************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
  2. ************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
  3. ************* EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
  4. ************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
  5. ************* EnergyPlus Terminated–Fatal Error Detected. 1 Warning; 1 Severe Errors; Elapsed Time=00hr 00min 9.34sec
tutorial 01.gh (489 KB)
tutorial 01.3dm (85.4 KB)
Hi Reid ,
Yes, because the default values of the heating & cooling Sizing Factor from the EnergySimPar component was empty. That problem was fixed (about 2 months ago).
Try to Update all of the HB & LB components and file. That should solve the problem.
-Omid
