Honeybee simulation model is not showing up
I am trying to run an illuminance simulation, but as I am manipulating grasshopper, the simulation model is not showing up.
I am a beginner and do not know the cause.
I was wondering if you could help me.
you have to set a brep? I think??
if you have already, then enter z then press enter , a then press enter , e then press enter in the rhino command so you can zoom to the geometry
I apologize for the delay in replying to you.
Thank you for your advice. I will check it.
