Hopefully someone can help me with this. I am using the Honeybee_EnergyPlus Window Shade Generator. However, that applies shading to all orientations at once, and I would like to evaluate each exposure separately. In theory the “_depth” input, can recognize a list and will assign different depth to each exposure.
The help reads as follows: …“inputing 4 values for depths will assign each value of the list as follows: item 0 = north depth, item 1 = west, item 2 = south depth, item 3 = east depth”… However, I have done this and it is till applying the first value as the depth for all exposures.
Any workaround that you can think of? I will appreciate your help.
Regards,
Francisco Contreras
