How can I change the yellow color?
Hi I can’t change the yellow color with the green one. How can I do it?
I have also tried to right click the Geo component at your walls output and disable its preview and to delete the Geo component and plug the walls output directly into the G input on the preview component but it doesn’t work.
You should look for the HB_FacesByType component, instead of the HB_VizByType, like so:
Thank you, it works!
