How to add text result labels to the recolorMesh
Dear All,
could you share an example how to add text result data labels to the e.g. VSC results being ploted with reColorMesh.
I would like to achieve the text labels of resulting VSC (%) being ploted on the calculation surfaces (grid points).
Best regards,
Milan.
@janak Maybe you can use countour mesh compotent.
Thank you very much for your advice. However I am not able to locate this component Ladybug_CountourMesh in my standard Ladybug 0.0.67 distribution?
Best regards,
@janak The answer is yes. Ladybug_CountourMesh is located in the SubCategory “7 | WIP”
Thanks a lot. I have already found it :slightly_smiling_face:
Now I am really having a problem to get it work. It will not accept any of _inputMesh with error that it can only work with planar meshes BUT I am having only one planar surface connected to it.
Any example of how to generate _inputMesh for countorMesh?
Best regards,
