I’d like to have polygonal mesh cells, I guess it’s a parameter in snappyHexMeshDict from the pdf made by Andrew Jackson (p23 and following) but I can’t find this parameters in BF.
Regards
Final-AndrewJacksonSlidesOFW7.pdf (2.1 MB)
Regards
Any standard case with snap=True will generate the type of mesh shown there. You can run one and visualize the surfaces near your refinements to validate that.
Hum, I will check again in ParaViewer but I had the impression it was only doing square and triangle mesh (side view).
