how to extract ladybug and honeybee day hour result into excel for each test point. Thanks.
Hi Willian,
Surely exists a plugin to do that, but the easiest way is : a) connect a panel component to the output of the data you want to extract, b) right click and appears a menu…there are 2 options to copy data, one includes the index relating to each data and other just data…then you can paste it in excel
Hi @willian what results are you explicitly talking about? E+/OS simulation results? comfort mapping, radiation analysis?
I am working on a simulation process of outdoor thermal comfort (utci) to collect data for training a ML model, what is the best way to collect data in excel file for each test point, BTW i also prepared an excel sheet form for the training process.
Hi Wiliam, I had the same problem. I used Colibri: from HB to Colibri Inputs, and from Colibri Inputs to Colibri Aggregator.
Asking about exporting comfort mapping data for thousands of simulations regarding outdoor thermal comfort
