How to generate the output summary report table in HTML format?
May I ask how to get the output summary HTML table used to be generated by the following objects in IDF file?
Output:Table:SummaryReports
OutputControl:Table:Style
Thanks!
Didn’t tested yet, and can’t do it right now, but have you tried inputing a panel into the additionalStrings_ input of the RunEnergySimulation?
Noted with thanks, Abraham! will try your suggestion later.
You can connect them to simulationOutputs_ as a list of strings.
