Hi there!
Happy December
Recently I am trying to solve a previous issue that causes ASE to always zero in five-phase simulation. I am trying to look into the .rad file and .bat file to see if there is anything abnormal regarding ASE. By far I am able to locate the project folder. However, I am not sure about:
(1) which .rad files and bat files should I specifically review in order to diagnose ASE results?
(2) Once the target .rad files and .bat files are found, how can I identify if there is an error causing ASE zero?
(3) I am also suspicious if I found the correct master folder: by recognizing the date, I remember that I ran five-phase simulations by using HB[+], however, these files are under the “ladybug” folder…Did I just have the wrong place? if so, where are the HB[+] results usually stored?
I screenshot the folder contents listed as below. Please help me to point out .rad and .bat files so I can upload them too.
The below image shows the content of the five-phase folder:
The below image shows the content of the “result” sub-folder:
The below image shows the content of the “scene” sub-folder:
The below image shows the content of the “sky” sub-folder:
The below image shows the content of the “tmp” sub-folder:
Any suggestion will be appreciated!
Di
