How to make a monthly averages of dry bulb temperature?
Thanks
Use the LB_selectAndAverageData component.
Hi Abraham,
I’m having similar doubts while calculating average dry bulb temperature and saw your post here.
I have two questions I’d like to ask you.
- For the newer hbt (not legacy), can LB_selectAndAverageData still be used? (I tried it but seems not showing values?) If not, which one could be used for calculating average?
- Is there a way to calculate an average Tdb for several months such as during heating season?
Thank you in advance!
For the average you can use the LB Time Interval Operation (TimeOp) component.
For the period average you can try something like this:
Thanks! I’ll try those components later.
