I wanted to know:
- If it is possible to provide 2 different glass VLT in single HB Zone/single HB surface without using EP construction material.
- Is there a way to provide 2 different glass RAD material to the surface first and then by using “Add glazing” add window surfaces to the HBZone/HBSurface
Thanks in Advance!
