Hello everyone,
I was testing the parametric daylight analysis example file from GitHUB that uses the Ladybug_fly component to generate multiple results files, and i want to know if there is some way to bring all those results at once to grasshopper. In the example file there are only 20 results and it is possible to copy each result file path manualy to grasshopper, but with more results it becomes impraticable.
Thank you all
Allyson Santos.
There is a way, but it can be a bit tricky. If you have the plug-in called Human (get it at food4rhino), there is a component (Directory Contents) where you can see all files/folders within a folder. You can use that to look in your “mother-folder”, where all your daylight analysis files are. Plug the complete list of contents from the “mother-folder” into the HB “Lookup Daylight Folder” component, and you should be able to get the results.
I, however, have had some issues with connecting multible paths into the daylight lookup component. Therefore it could be an idea to generate the file paths directly, with concatenate and using “read file” to get the data.
Hope it helps a little
/Christian
I will try using the DataRecorder component.
Thanks for your answers guys, i tried the Directory Contents component and the DataRecorder component, they both worked really well. I will try later use the human component with concatenate.
Thanks for your help,
Allyson Santos.
