I want to analyze the illuminance for my model which has shading. I created the shading with Shade Generator, but in the “Run Daylight Analysis” component, there aren’t any place for connecting shading in. I wanted to ask how I can connect shading in the calculation process?
Also, I wanted to ask is there anyway to have just one legend for the whole analysis? Now I have one legend for each floor, and I move all of the into the Rhino origin. but it is not a good approach. I wanted to ask is there any approach that I can merge them together?
I attach my file in here.
Thanks so much for the reply.
“For daylight analyss using Radiance. therer is no shading compotent. You can connect shading to opaque surface .”
I tried it but it didn’t take into account the shadings. Did I do it right?
“For combine the multi grid results to one legend, you need two coompotent : mesh join and flatten the result.”
Thanks so much. you solved my legend problem.
Yes, I set it to zero to test it for without shading. when I have zero (no shading) and I run it for illuminance level, the results do not have any difference with the results when I have shadings.
Thanks so much. Appreciate it.
A question separate from the Grasshopper, what is your system, it seems super fast. Mine takes time for each analysis. And also, how you made this gif? In other word, how you make your analysis automatic? I am new with grasshopper, and this graphics seems interesting for me for the presentation.
Thanks.
Helia
