Just updated to the latest development version (Up to Versioner 1.2.3).
When i open an existing file that uses the Image Viewer it doesn’t show (for instance the Viewbased.gh example).
Can you assist?
Can you assist?
Solved:
Quit RH.
Delete the folder:
C:\Users\USERNAME\AppData\Roaming\Grasshopper\Libraries\ladybug_grasshopper_dotnet
Run the Versioner
again.
Quit RH.
That’s it.
Yep, we just moved the Image Viewer from Legacy to LBT now that we have full support for view-based radiance recipes in LBT.
