Hello all. I generated a future predicted Epw file for the year 2020 using Meteonorm for a location. I tried importing the file using LBT Import Epw component but it threw an error. The same file I tried opening with Ladybug Legacy it is working without issue.A bit confusing.
Legacy might be able to import the EPW but I don’t think any of the Legacy climate graphics can handle the extra 24 values (or, if they do, the probably do so incorrectly).
You can import an EPW that’s for a leap year with the new Ladybug plugin as long as it’s internally consistent. For example, here I am loading up an EPW for Boston in 2016:
Actually, you can see here’s that it’s one of the variables in the header of the EPW that tells EnergyPlus and Ladybug that the calculation is for a leap year:
So, if you just edit the incorrect header of your Meteonorm file, you should be able to import it with Ladybug and simulate it In EnergyPlus without issues.
Hi again @Chris can you please share your 2016 boston file. Still i am not able to make it run on LBT. For now i just deleted the feb 29 data to make it work.
