Im testing the Import gbxml and I think I found a bug when importing a OS or IDF file that includes a transmittance schedule assigned to a shading surface.
It throws a “Failed to apply energy properties to the model” error:
FYI, if you want schedules to be successfully imported to Honeybee, you have to import the OSM (instead of the IDF) since IDF does not support ScheduleRulesets.
