HI!!
My Lab always use ladybug.
We want to use “Import ground temp”,but there is something wrong with it.
It say “1. Solution exception:unsupported operand type(s) for -: ‘tuple’ and ‘float’”
Could you give me your advice
Best Regard. Hiro
HI!!
Best Regard. Hiro
Hi Hiro,
Please reinsert the component. The one in the image corresponds to a previous version. You probably updated using the updater component. This is one of those cases that this should be done manually since the amount of input/output items changed.
Saying that i’ve found a bug:
When i set the visualisedata_Month FIRST to true i get the following error:
Then i set the visualisedata_Season to true (and the previous to false). It works. Then i set again the Month to true and now it works.
Small bug …
Hi Abraham.
I reinsert this component from https://github.com/mostaphaRoudsari/ladybug/tree/master/userObjects.
but this version is ver 0.058.
is this component is wrong?
Best Regard. Hiro
It is indeed 0.58. You should see 3 input items: epwfile, visualisedata_Season and visualisedata_Month
Hi Hiro
Can you email me your file to ajszilasi@gmail.com I’ll have a look and get it fixed ASAP for you
Sorry for not seeing your question earlier!
Hi Abraham,Anton
thank you for your kindness.
I can work Groundtemp because my epw have no ground temperature data.
Sorry for late replay.
Hi Anton,
You can follow my description above to dsee the problem sequence.
Hi Hiro
Thats interesting I thought all epw files have ground temperature data can you tell me what location your epw file is and I’ll take a look if some epw files dont have a location I need to build a check in that detects this
