Hello all,
I am wondering if it is possible to import HVAC configurations to Honbee components?
Hello all,
No.
@MingboPeng is it something that Ironbug might support at some point?
@sz, can you also add a little bit more details on your workflow.
PS: Can you also set up your profile picture? Thanks!
Yes, I have been working on it for several days. But would like to hear more details about the workflow that @sz is expecting.
@MingboPeng @mostapha Thank you guys for replying.
I am new to OS, E+ and Honeybee, so I am not really sure what I am doing here. So the followings are the requirements that I need to model; they are essentially the fundamental set-up. Could you please let me know what are the best Honeybee components to use for this scenario?
• Heat = ON IF Temperature < 20°C; otherwise, Heat = OFF
• Cool = ON IF Temperature > 27°C; otherwise, Cool = OFF
• Heating capacity = 1000 kW (effectively infinite)
• Effective efficiency = 100%
• Cooling capacity = 1000 kW (effectively infinite)
• Sensible cooling only; no latent heat load calculation
• Waste heat from fan = 0
Thanks a lot
SZ
The HVAC system configurations provided by Honeybee’s HVACSystemsList
is not adequate to suit my need. Therefore, it might be easier to import my own HVAC configurations.
I will try ironbug shortly
@sz
If understand your system correctly, it is basally an “Ideal Air Load” system, with heating and cooling set points.
@MingboPeng I am not sure how this thing works though. What is the difference between heatingSetPtSchedules_
and heatingSetPt_
? What are the coolingSetback_
? In addition, how to define the capacity of the heating and cooling system for the ideal air load model?
Thank you very much for your help.
SZ
is an hourly setting for heatingSetPt_
heatingSetPt_
is a constant value for entire year.
coolingSetback_ is the temperature to maintain when the space is not occupied.
ideal air load system: basically is a system has infinite capacity and 100% efficiency.
