Hello Chris,
we meet at the Advancing Computational Building Design conference in NY this year.
great presentation BTW.
I’m experiencing memory problems with RH6.
I’m running energy and illuminance models at the same time for a residential building. It is just one typical floor with 16 thermal zones. Since it is a large number of iterations (1296), I divided them into 6 files to run all them in parallel in a server, around ~200 each.
These 6 Rhino sessions run fast in the beginning, about 2 to 3 mins the initial runs, then 4-5 mins at iteration 30, 6-7 mins at 50, 20-25 at 100, and then they crash. They are eating all the memory until they die.
I have done this (running 6 or more RH sessions in parallel) before with RH5, but RH6 with the latest versions of Plus 0.0.04 and legacy 0.0.63 is showing these issues. Do you know if there is any RH6 settings that I need t adjust? or any advice in this matter?
Thank you!
