If you’re building a Honeybee energy model, it’s going to be much simpler to evaluate PMV comfort by running the HB PMV Comfort Map. The result will also be more accurate because that PMV comfort mapping recipe can account for shortwave solar reflections (given that the shortwave calculation is run using Radiance).
This isn’t to say that you couldn’t also do a comfort analysis using those components but you should be using the rad_temp from the energy simulation as your _longwave_mrt. Also, you should make sure that your components are of the correct version since it seems that relative humidity isn’t being requested for some reason:
