Information about "Honeybee_Read hourly results from Annual Daylight study"
Hi everyone,
does anyone know the unit of the “illumLevelsNoDynamicsSHD” output of the “Honeybee_Read hourly results from Annual Daylight study” component?
What I mean is, are they lux, candela, wh/m2, etc…?
Thanks for your replies =)
Unless you have used DSParameters to change the analysis type the values are illuminance values in lux.
Ok, thank you very much Mostapha!
Hi @mostapha ,
I have a question here. Although I tested this component with several different test points, it has given the same result. Could you please check the script in this component?
Thanks.
