Hi my friend, I try to use Ladybug_Fly battery to automaticlly run multiple butterfly airflow simulation,aim to get the wind speed under several different boundary conditions. but because butterfly solution simulation process will iterative several times, so data record battery will get severl useless data during this process. so I would like to know if there is a good way to solve this problem?
Thank you for your kindly help in advance!
