Integrating Daylighting Results to Energy Analysis
Hi Mostapha
This is Ladan, I hope you are doing well. Congratulation on the great success of your tool! this is amazing! I could see this coming many years ago :slight_smile: I have one question for you. Can you read the daylighting annual results created by RADIANCE/DAYSIM in your EnergyPlus file and modify the lighting schedule based on the illuminance values calculated by RADIANCE?
Thank you so much
Ladan
Check the hydra example.
Thank you very much!
