Parametric_Colibri_Skylight.gh (1.2 MB)
I’ve been trying to integrate daylight and energy simulations (using Colibri) for different roof to skylight ratios. But I’m not sure about how to connect the ratio input in the skylight based on ratios component to the Colibri iterator. Could someone help?
There’s an example on hydrashare where Chris set up collibri to vary a few parameters (including glazing based on ratio). Let us know if this helps you setup your experiment.
