Hi !
I’m running a large number of annual radation studies using HB+. To save time I’m writing all of the batch files first, running them in parallel and then performing data analysis outside grasshopper.
The result files (“diffuse…scene…default.ill” + “sun…scene…default.ill” = “scene…default.ill” ) contains data that is different from when you load the same result files into grasshopper using “HoneybeePlus_Hourly Values”. Have tried going through the code looking for a formatting of the data from the results files when it is loaded into grasshopper, with no luck,
Interestingly when performing DC gridbased illuminance simulations in HB+ the content of the result files matches the output of “HoneybeePlus_Hourly Values” when you load it into grasshopper.
So in a nutshell I am trying to understand the unit of the data in the result files from an HB+ annual radation study and how to convert it to kWh or Wh.
I bet @mostapha has a take on this
Cheers Tobias
