Introducing Context into a Daylight Simulation Process
Hello! I am trying to introduce the city context into my daylight simulation analysis within the script provided here: http://hydrashare.github.io/hydra/viewer?owner=mostaphaRoudsari&fork=hydra_1&id=Honeybee_Grid-based_Daylight_Simulation_Example_III&slide=0&scale=1&offset=0,0
I have tried to introduce the context geometry within the same brep component containing the building geometry and the result is no data. Where should I introduce the building’s context instead?
Thank you in advance.
Javier
Hard to say without the file but in principle you shoul connect the geometry to the createHBSrfs component, for daylight simulations.
Finally, there was a problem with my file. It is already solved! thank you!
