Hi Mingbo, @MingboPeng
Thank you for developing the Ironbug tool, it significantly helps us build up a customized HVAC system on the grasshopper platform.
Recently, I meet a problem with the input heat recovery rate of the Heat Exchanger. I input 0.65, but the number was not changed when I opened the Openstudio to double check.
Could you please help me figure out the reason? the file is uploaded for your review.
Thank you!
ironbug0209.gh (83.3 KB)
