Is this component used to simulate evaporative cooling
@sandra This component is the detailed natural ventilation setting. As I know, you can use Ironbug plugin for evaporative cooling simulation.
hi thank you sir for your answer but which pluging this component, please
Hey Ming, would you happen to know how to tweak that pad to control the water temperature at the inlet of it? I know that it has no parameter to control that. In my case I need to model it that it is taking cooled water
