Issue with Energy Simulation in Grasshopper
Hello, sorry for my poor English (please let me know if there’s anything unclear).
I’m trying to run an energy simulation in Grasshopper. Previously, using the ModelToOSM component, I could generate an IDF file and successfully run it to produce CSV results.
However, when I tried the same GH file on a different computer, the simulation ran with EnergyPlus 23.2.0, even though the installed version is 24.2.0. Additionally, the CSV file was not generated.
Another issue is that when I use the RunIDF component and connect the zsz output, I don’t see any results, which used to work fine on the previous setup.
Could you help me identify the cause of these issues? Thank you!
I’m sorry that I cannot upload screenshots because I’m a new user on this forum. Could you help me identify the cause of these issues? Thank you!
