Hi mostaphaRoudsari,
I install the new Butterfly and blueCFD successfully but I found an issue is that if I connect the decompose_par_dict, it will be ended before starting time loop . Hope u can understand what I mean. Cheers
Best regards
James
Best regards
James
It’s hard to say. It might be that you have the results of an older study which was not run in parallel.
You should share a screenshot and the log for the error.
