I keep getting the attached error despite, at least to my perception, following the prompting instructions for resolution.
I have tried nearly all afternoon try and overcome this issue. My suspicion is I’m overlooking something obvious. But I can’t seem to deduce what that may be.Any help much appreciated!
The problem seems to be OpenStudio_Standards.json. The size of the file should be 2,766. Can you download the attached file, replace it in the folder and then disable/enable honeybee_honeybee component. That should solve the problem.
Thank you very much! After replacing both files, that you provided, it now seems to be working. So I don’t which was causing the error. Really appreciate the swift response :)!
Hello @mostapha
These files ( OpenStudioMasterTemplate.idf) have expired here. It is possible to upload them again !! Thankful
I could not download these files from GitHub.
