Issues with UTCI Comfort Map
Hey,
I’m having issues with UTCI, since it comes the message:
  1. Solution exception:The recipe failed to run with the following summary:
Scheduled 33 tasks of which:
  • 13 ran successfully:
    • 1 CopyResultInfo(…)
    • 1 CreateDirectSky(…)
    • 1 CreateModelOccSchedules(…)
    • 1 CreateModelTransSchedules(…)
    • 1 CreateResultInfo(…)
  • 2 failed:
    • 1 CreateRadFolder(…)
    • 1 RunEnergySimulation(…)
  • 18 were left pending, among these:
    • 18 had failed dependencies:
      • 1 CopyGridInfo(…)
      • 1 CopyRedistInfo(…)
      • 1 CreateDynamicShadeOctrees(…)
      • 1 CreateOctree(…)
      • 1 CreateOctreeWithSuns(…)
Use the report_out attribute of recipe settings to see a full report.
Does anyone know how to solve it?
2023-07-18 22:55:36 INFO: Started running CreateModelOccSchedules…
2023-07-18 22:55:37 INFO: Started running CreateViewFactorModifiers…
2023-07-18 22:55:37 INFO: Started running CreateModelTransSchedules…
2023-07-18 22:55:38 INFO: Started running SetModifiersFromConstructions…
2023-07-18 22:55:39 INFO: Started running CreateSkyDome…
2023-07-18 22:55:39 INFO: Started running CreateWea…
2023-07-18 22:55:40 INFO: Started running CreateSimPar…
2023-07-18 22:55:41 INFO: …finished running CreateSkyDome in 0:00:02
2023-07-18 22:55:41 INFO: …finished running CreateWea in 0:00:01
2023-07-18 22:55:41 INFO: Started running CreateResultInfo…
2023-07-18 22:55:42 INFO: Started running CreateDirectSky…
2023-07-18 22:55:43 INFO: …finished running CreateResultInfo in 0:00:01
2023-07-18 22:55:43 INFO: …finished running CreateSimPar in 0:00:02
2023-07-18 22:55:43 INFO: Started running CopyResultInfo…
2023-07-18 22:55:43 INFO: copying input path…
2023-07-18 22:55:43 INFO: …finished running CopyResultInfo in 0:00:00
2023-07-18 22:55:44 INFO: Started running RunEnergySimulation…
2023-07-18 22:55:44 INFO: [{“path”: “sky.mtx”, “full_path”: “C:\Users\USURIO~2\AppData\Local\Temp\tmpzvam1duj\sky.mtx”}]
2023-07-18 22:55:44 INFO: …finished running CreateDirectSky in 0:00:02
2023-07-18 22:55:45 INFO: Started running CreateTotalSky…
2023-07-18 22:55:45 INFO: Started running GenerateSunpath…
2023-07-18 22:55:45 INFO: gendaymtx: reading weather tape ‘sky.wea’
2023-07-18 22:55:45 INFO: gendaymtx: location ‘Goiania-Santa.Genoveva.AP’
2023-07-18 22:55:45 INFO: gendaymtx: (lat,long)=(-16.6,49.2) degrees north, west
2023-07-18 22:55:45 INFO: gendaymtx: outputting suns to file
2023-07-18 22:55:45 INFO: gendaymtx: done.
2023-07-18 22:55:45 INFO: …finished running GenerateSunpath in 0:00:00
2023-07-18 22:55:46 INFO: Started running ParseSunUpHours…
2023-07-18 22:55:47 INFO: [{“path”: “sky.mtx”, “full_path”: “C:\Users\USURIO~2\AppData\Local\Temp\tmp1od2etc3\sky.mtx”}]
2023-07-18 22:55:47 INFO: …finished running CreateTotalSky in 0:00:02
2023-07-18 22:55:48 INFO: …finished running ParseSunUpHours in 0:00:02
2023-07-18 22:56:07 INFO: …finished running CreateModelOccSchedules in 0:00:30
2023-07-18 22:56:08 INFO: …finished running CreateModelTransSchedules in 0:00:30
2023-07-18 22:56:18 INFO: …finished running SetModifiersFromConstructions in 0:00:40
2023-07-18 22:56:19 INFO: Started running CreateRadFolder…
2023-07-18 22:56:31 INFO: …finished running CreateViewFactorModifiers in 0:00:53
2023-07-18 22:56:40 INFO: [22:56:40.552086 ERROR] :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb failed with message cannot load such file – to_openstudio in eval:134:in require' 2023-07-18 22:56:40 INFO: eval:134:in require’
2023-07-18 22:56:40 INFO: :/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in require' 2023-07-18 22:56:40 INFO: C:/Users/Usuário/ladybug_tools/resources/measures/honeybee_openstudio_gem/lib/measures/from_honeybee_simulation_parameter/measure.rb:35:in <top (required)>’
2023-07-18 22:56:40 INFO: :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:344:in load' 2023-07-18 22:56:40 INFO: :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:344:in apply_measure’
2023-07-18 22:56:40 INFO: :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:in block in apply_measures' 2023-07-18 22:56:40 INFO: :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in each_index’
2023-07-18 22:56:40 INFO: :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in apply_measures' 2023-07-18 22:56:40 INFO: :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in perform’
2023-07-18 22:56:40 INFO: :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step' 2023-07-18 22:56:40 INFO: :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in run’
2023-07-18 22:56:40 INFO: :/openstudio_cli.rb:1187:in execute' 2023-07-18 22:56:40 INFO: :/openstudio_cli.rb:817:in execute’
2023-07-18 22:56:40 INFO: :/openstudio_cli.rb:1984:in <main>' 2023-07-18 22:56:40 INFO: eval:188:in eval’
2023-07-18 22:56:40 INFO: eval:188:in require_embedded_absolute' 2023-07-18 22:56:40 INFO: eval:173:in block in require_embedded’
2023-07-18 22:56:40 INFO: eval:167:in each' 2023-07-18 22:56:40 INFO: eval:167:in require_embedded’
2023-07-18 22:56:40 INFO: eval:126:in require' 2023-07-18 22:56:40 INFO: eval:3:in
2023-07-18 22:56:40 INFO: [22:56:40.552505 ERROR] Found error in state ‘os_measures’ with message [“:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb failed with message cannot load such file – to_openstudio in eval:134:in require'\neval:134:in require’\n:/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in require'\nC:/Users/Usuário/ladybug_tools/resources/measures/honeybee_openstudio_gem/lib/measures/from_honeybee_simulation_parameter/measure.rb:35:in <top (required)>‘\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:344:in load'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:344:in apply_measure’\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:in block in apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in each_index’\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in perform’\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in run’\n:/openstudio_cli.rb:1187:in execute'\n:/openstudio_cli.rb:817:in execute’\n:/openstudio_cli.rb:1984:in <main>'\neval:188:in eval’\neval:188:in require_embedded_absolute'\neval:173:in block in require_embedded’\neval:167:in each'\neval:167:in require_embedded’\neval:126:in require'\neval:3:in ‘::/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:654:in rescue in apply_measure'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:651:in apply_measure’\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:in block in apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in each_index’\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in perform’\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in run’\n:/openstudio_cli.rb:1187:in execute'\n:/openstudio_cli.rb:817:in execute’\n:/openstudio_cli.rb:1984:in <main>'\neval:188:in eval’\neval:188:in require_embedded_absolute'\neval:173:in block in require_embedded’\neval:167:in each'\neval:167:in require_embedded’\neval:126:in require'\neval:3:in '”]}
2023-07-18 22:56:40 INFO: — Logging error —
2023-07-18 22:56:40 INFO: Traceback (most recent call last):
Exception ignored in: <finalize object at 0x1ba34682640; dead>
File “c:\users\usuário\ladybug_tools\python\lib\weakref.py”, line 572, in call
return info.func(*info.args, **(info.kwargs or {}))
File “c:\users\usuário\ladybug_tools\python\lib\tempfile.py”, line 797, in _cleanup
_shutil.rmtree(name)
File “c:\users\usuário\ladybug_tools\python\lib\shutil.py”, line 516, in rmtree
return _rmtree_unsafe(path, onerror)
File “c:\users\usuário\ladybug_tools\python\lib\shutil.py”, line 404, in _rmtree_unsafe
onerror(os.rmdir, path, sys.exc_info())
File “c:\users\usuário\ladybug_tools\python\lib\shutil.py”, line 402, in _rmtree_unsafe
os.rmdir(path)
PermissionError: [WinError 32] O arquivo já está sendo usado por outro processo: ‘C:\Users\USURIO~2\AppData\Local\Temp\tmpypea69te’
