Label zones in honeybee error
Hi
I’m experiencing the following error using Label Zones and Label Zone Surfaces:
Solution exeption: name: ‘W’ is not defined
this notification appears on both the commands as i place them on the canvas
Any idea??
I’ve Rhino GH and HB updated.
Thank you for your help
Please also put Ladybug_Ladybug on the canvas and recompute. That should make the error disappear.
Thank you so much
I don’t have any idea why, but suddenly it started to work .
Maybe you are right because in the different things i tried, I put Ladybug on canvas as well but I didn’t remember the precise moment when it started to work
SOLVED
A lot of functions in Honeybee use classes in Ladybug. Therefore always keep LB and HB both on the canvas for any Honeybee simulations.
