Ladybug Base Type Missing
“User Objects can’t be made because base type is missing” appears when trying to run ladybug. All ladybug files were allowed in their properties and GhPython is installed and seems to work. Any ideas what I can do to get ladybug to run?
Are you sure that this is an issue with Ladybug? It sounds like it’s a general issue with your Grasshopper UserObjects, for which you should search the McNeel forum:
