HI all
I want to create monthly cooling and heating loads bar chart without using [HB thermal load balance] object.
I made header and monthly values datasets and plugged to [LB construct data] but it expresses following error :
1. Solution exception:‘str’ object has no attribute 'analysis_period’
How can I solve this?
- I solved the problem somehow, gonna upload later…
