Ladybug doesn't read epw file
Hi Mostapha,
I have a problem to reading epw file with Ladybug as indicated in image below
Note: I have installed the latest version of Grasshopper, Ladybug and GHpython and also Rhino 5.0 32bit.
Can you please help me.
Regards
Giorgio Butturini
You need to connect the panel with the EPW file to a LB_importEPW component.
Now you are connecting it to LB_Open weather file, which need a boolean component to import the file (see the hint in the component).
And if you are here, i suggest to update to the more recent version (not related to your problem though)
Yes, Done!
Thanks
GB
Thanks for handling this, Abraham. And, yes, you should update Giorgio! We have a lot of awesome stuff in the newer version!
