Ladybug doesn't run
I tried several times already to install the ladybug plugin. The installation is completed but when I drag components (such as sun path or windrose) and connect them with ‘location’ they turn red with the following messages: 1. Solution exception:‘Text3d’ object has no attribute ‘HorizontalAlignment’. / 1. Solution exception:‘Location’ object has no attribute ‘header’. (images attached)
I would appreciate a lot if you can help me with this
Maria
What version of Rhino are you using (including both major version number and the service release)?
Note that the LBT plugin does not work with Rhino 5 and, if you have Rhino 6 or 7, then upgrading to a newer service release should fix the issue.
I’m using Rhino 6 (6.1.18023.13161, 23/01/2018) and the latest version avaliable of ladybug
That is a very old version of Rhino 6. I recommend upgrading to at least Rhino 6.27 and, ideally, you should upgrade to the latest version of Rhino 6, which is 6.35.
Okay, I’ll try that then see what happens
