LADYBUG Error. please help to solve
hello I have Rhino 5.0 version. and a grasshopper 0.90076 version and ladybug newest 2017 plug in ( to install the plug in i dropped the file into grasshopper window and looks like it installed- it asked me if i wanted to replace files and i did. now i am trying to create anything with ladybug- i cannot even construct the location…gives an error, please see attached, please please advise.
Thank you in advance… please email umnicka92@gmail.com or send a reply here please.
  1. Remove the current installation: http://hydrashare.github.io/hydra/viewer?owner=mostaphaRoudsari&amp…;
  2. Make sure you have GHPython installed and the GHA file in unblocked.
  3. Install Ladybug + Honeybee!
installed GHPython now will try to remove the installation. will try, thank you again
The definition that removes installation is using GHPython. I should have changed the order between 2 and 1.
this is what i am getting now.please help
but i did remove as per instructions
Just select Replace All. That shouldn’t make any issues for running ladybug and honeybee.
All works thank you :slight_smile: do you know much about CDF- Fluid dynamics- to try air flow ?
Hi, out of curiosity why i dont see colored chart and model on my side. i am following your youtube video(which is great) :slight_smile: may you advise please?
you need to turn of the preview of the components in Grasshopper, and also hide the geometries in Rhino.
