i have downloaded a epw file but i’m not able open it in ladybug even after doing “copy as path” and pasting it in panelbox and when i try to connect it to importEPW ,the file is not readable. so can someone help me with this ?
please share the EPW file and the GH definition you are using
(also you can try using the following GH definition EPW .gh (371.0 KB) )
thankyou so much. it worked.
