Ladybug problem, error with firewall
Greetings. I wanted to ask you for help regarding a problem that occurs to me since I installed rhino 7 with ladybug 1.5. This is a problem that occurred both when I tried to install Ladybug and now when I’m trying to import an EPW file. I’ve read some discussions where it says that the solution is to disable the firewall and in fact when I disable it this works. But I wanted to know if there is a general solution that solves this without having to go to disable windows security every time.
This is the error that occurs:
Runtime error (PythonException): Download failed with error: Unable to connect to remote server.
