Ladybug Runtime error (Win32Exception) : Windows error
Hey ya’ll - been having some issues getting the visualizers to work. Every visualizer that I put into the canvas immediately has a Windows error pop up. I tried doing some debugging methods found in the forum such as using the versioner but even that has the Windows error. Any help would be appreciated! Also on a Mac. Thanks
Please check the following:
  1. Have u unchecked the block option in properties tab before unzipping the installation folder (if u downloaded for Rhino)?
  2. Is your internet fine and do you have full administrative priveliges to install third party softwares in ur system?
If the problem is not fixed after checking the above things, download installer from Pollination website.
