I am trying to visualize Annual Daylight results with LB Spatial Heatmap and its error is 1. Solution exception:Expected the number of data set values (583) to align with the number of faces (547) or the number of vertices (634).
Consider flattening the _values input and using the “Mesh Join” component to join the _mesh input.
I Already use the mesh join componet and tried to flatten the _value input, but it still not working.
Could you please provide guidance on how to resolve this issue? Thank you for your assistance.
