hi all
I modeled a 3d shape in rhino, and then i calculated radiation on shape by ladybug.
ladybug use mesh for gaining radiation on a model??
hi all
Can you explain a little bit more what do you mean here? uses mesh center points and normal vector at that center to generate sensors to calculate radiation.
Dear @mostapha
I created a 3D model in rhino and then I calculated radiation on model by .
Now I need to know
You can get both of them from the outputs of the radiation component.
