Laminated Glass
Is it possible to create laminated glass with Sentryglas interlayers by using the EP Construction component? I’ve had a a lot of success creating IGU’s so I’m hopeful I can make laminated glass without just plugging in values for the EP window material component. If it is possible, how would I create a material for the interlayer (as it is not an opaque material, glass material, or air gap)?
Thank you!
Aaron
Hi Aaron,
I don’t know the answer to this question myself. Doing a quick search I found these two:
This paper suggests using simplified method (http://gaia.lbl.gov/btech/papers/2804.pdf)
You can also use Window to generate the material data (http://bigladdersoftware.com/epx/docs/8-0/input-output-reference/pa…)
My suggestion for you is to send your question to (unmethours.com).
-Mostapha
