i noticed that setting an “analysis period” using the corresponding LB+ component uses a different hour count convention than e.g. using HB+ to create a schedule. The input "start hour = 9 , end hour = 17 in LB+ includes the hour from 17:00 to 18:00, while in HB+ this is not the case. Is this intentional? You can see the difference in the attached image.
