LB Direct Sun Hours Simulation
i would like to use the LB Sunpath to do a LB DirectSunHours simulation. As a weather file i use an epw file of the epw map. The simulation should only be carried out for sun positions above 11 degrees (DIN EN 17037). Can someone help me?
Kind regards
This is duplicate. Let’s continue the conversation here:
