LB Mass Arithmetic Operation - Header changed
Want to report that the LB MassArithOp components doesn’t keep the original header as it was before the operation. The type of the data is skipped.
Will be nice if it does.
That’s why the component has a type_ input @AbrahamYezioro
Usually, the original type is different than the final one when you perform a mass arithmetic operation on it so you can plugin in whatever text you want for the new type.
Of course!!!
