LB Thermal Shade Benefit question
Hello
In LB Thermal Shade Benefit
how to use these output to calculate the temperature?
shade_help: The cumulative degree-days per square area unit helped by shading each
            cell of the shade. If a given square meter of _shade_geo has a helpfulness
            of 10 degree-days/m2, this means that a shade in this location provides
            1 day of sun protection from conditions 10 degrees warmer than the
            _up_threshold_ to the _study_region.
        shade_harm: The cumulative degree-days per square area unit harmed by shading each
            cell of the shade. If a given square meter of _shade_geo has a harmfulness
            of -10 degree-days, this means that a shade in this location blocks
            1 day of sun duirng conditions that are 10 degrees Celsius colder than
            the _low_threshold_ to the _study_region.
        shade_net: The sum of the helpfulness and harmfulness for each cell. This will be
            negative if shading the cell has a net harmful effect and positive
            if the shade has a net helpful effect.
