I have been trying to use LB visibility percent.
However, it seems it does not work correctly as all results show zero.
I am using Rhino7 and the component version is 1.5.0.
Can anyone give me some advice?
Looks like your view points are further away from your geometry than your max distance limit. Either disconnect the slider connected to max distance or increase the slider value.
